Pipeline rule, multiple values using regex function return an empty table
Thanks a lot @jan …it will be helfull.
the log entrie for testing was at the begenning :slight_smile: :
hostname hlspullpusher.hlspusher/41497 zf103: ‘QUOTED VALUE 1’ - unable to push HLS fragment ‘QUOTED VALUE 2’ : Server error ‘QUOTED VALUE 3’|#warning,hlspusher,local4,support
I will sugest to add this code example in the documentation.
the documentation is open source too - submit a PR and all are happy!
I just realised that the result from the group matches is indexed by string after seeing @jan’s example… it is result["0"] and not result[0]. Derp. Should’ve seen that… :smiley:
