is it possible to only select the value part of a json key pair when using select_jsonpath function?
I’m picking the timestamp key pair and need to pass it onto parse_date
but need to strip the value part only. I’m using split() at the moment to strip the actual timestamp but is it possible to pick the value part only using select_jsonpath() ?
