There are serveral places that “No results found” presents. i have search all source code files, it seems that there is no phrase “No results found” being found. did this not introduce by graylog source codes ?
indeed, i found the phrase text is not return by mongodb, but the programmed behavior on browser, when i pull down the select list, there has an event been triggered and rendering as following:
Eventually found it was introduced by react-select
and also i found there are release notes related to this:
## v0.2.10 / 2015-01-01
* fixed; More specific mixin name to avoid conflicts (css)
* fixed; Example CSS now correctly rebuilds on changes in development
* fixed; Values are now expanded correctly when options change (see #28)
* added; Option to specify "No results found" label as prop for i18n, thanks
[Julen Ruiz Aizpuru](https://github.com/julen)
