Nginx resolves as website with external IP
(Bill) #1
I’m a new system admin taking over for someone who installed Graylog, it seems to be working fine and reporting as intended. However I know nothing about the system so my apology for asking very novice questions. And having never worked with a reverse proxy before, my concern is that nginx shows up on one of our internal network scanners as a website with an external IP. Can someone please explain to me if this is normal or should I be concerned about this component of the implementation? Thanks much.
(Jan Doberstein) #2
Hej Bill,
without knowing anything about your Setup that question is not to answer from external. You should ask the person that created the setup to get details. As every setup is uniq and can be customized to your needs.
To learn something more about, just take a look at the documentation
(Bill) #3
Thanks Jan, I’ll try to locate the previous admin.
