New fields' visiblity to field test functions in same stage
I found that newly created field not visible to field test functions(such has_field and is_null/is_not_null) in same stage, but it is available to set_field function, is this a design behavior or bug(although i have reported a bug for this: https://github.com/Graylog2/graylog2-server/issues/4693) ? i have create a pipeline as following:
stage 0 match either
	rule "Test visibilty 1";
	rule "Test visibilty 2";
	rule "Test visibilty 3";
	rule "Test visibilty 4";
	rule "Test visibilty 5";
	true
	set_field("x_1","111");
	set_field("y_1",to_string($message.x_1));
	has_field("x_1")
	set_field("x_2","222");
	set_field("y_2",to_string($message.x_1));
	not has_field("x_1")
	set_field("x_3","333");
	set_field("y_3",to_string($message.x_1));
	is_null($message.x_1)
	set_field("x_4","444");
	is_not_null($message.x_1)
	set_field("x_5","555");
and input message, we will got:
more test shows that all evaluation against message fields in “when clauses” of rules are against the status of message field before that enter the stage where the rules in. and the status of message fields in the “then clauses” of rules are moving forward following those actions.
for example, following pipeline
pipeline "test field scope"
stage 0 match all
	rule "set y=y and z=z";
stage 1 match either
	rule "if y==y then z=zz";
	rule "if z==zz then z=zzz";
	true
	set_field("y","y");
	set_field("z","z");
	$message.y == "y"
	set_field("z","zz");
	$message.z == "zz"
	set_field("z","zzz");
get result: y=y, z=zz instead of y=y, z==zzz.
For reference:
