Hi all,
I’m trying to read multiline log files from another application server by Sidecar.
But I can’t read the last line.
Here is my Filebeat Multiline Pattern:
multiline.pattern: '^HELPDESK'
multiline.negate: true
multiline.match: after
Here is example log:
HELPDESK | 13-12-2019 08:20:30.841 | ilkerb | HOSTNAME | [73] | ERROR | HelpDesk.Operation.LoggerService | System.Web.HttpException (0x80004005): The controller for path '/favicon.ico' was not found or does not implement IController.
at System.Web.Mvc.DefaultControllerFactory.GetControllerInstance(RequestContext requestContext, Type controllerType)
at System.Web.Mvc.DefaultControllerFactory.CreateController(RequestContext requestContext, String controllerName)
at System.Web.Mvc.MvcHandler.ProcessRequestInit(HttpContextBase httpContext, IController& controller, IControllerFactory& factory)
at System.Web.Mvc.MvcHandler.BeginProcessRequest(HttpContextBase httpContext, AsyncCallback callback, Object state)
at System.Web.Mvc.MvcHandler.BeginProcessRequest(HttpContext httpContext, AsyncCallback callback, Object state)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
This is tokenizer which is used to format the logs:
tokenizer: "%{source} | %{logtime} | %{username} | %{hostname} | %{thread} | %{loglevel} | %{class} | %{message}"
Here is screenshot about problem:
