Migrate Graylog Journal/Messages (Single Node) to Multi-Cluster Node
Need to migrate from single node to multi-node setup (CE)
Cluster is already up and running pending the data or indices which is needed to be preserved for historical purposes (like 12 months)
Already performed snapshots via API and pending restoration of these snapshots to the new cluster.
the snaphosts are located here /mnt/efs/snapshots
  • OS Information: Debian12
  • Package Version: CE ver 6.3
single node :
multinode:
#Snapshots repo
path.repo: [“/mnt/efs/snapshots”]
Im using AWS EFS as storage, and this is mounted already on both single node and multi node setup.
used API curl commands no UI since using a CE
