Hi!
This should work like you expect, all you should have to do is to return the local metric registry as you did, and register the metrics themselves early, i.e. typically in the constructor.
The result of getMetricSet()
is being prefixed by the class name and id of your input.
I’ve just tried to add a simple counter to the random http input and it showed up without problems in the metric browser.
Do you have a link to the complete source somewhere?
My diff:
diff --git a/graylog2-server/src/main/java/org/graylog2/inputs/transports/RandomMessageTransport.java b/graylog2-server/src/main/java/org/graylog2/inputs/transports/RandomMessageTransport.java
index f42f904c4..d64309f80 100644
--- a/graylog2-server/src/main/java/org/graylog2/inputs/transports/RandomMessageTransport.java
+++ b/graylog2-server/src/main/java/org/graylog2/inputs/transports/RandomMessageTransport.java
@@ -22,6 +22,7 @@ import com.google.common.eventbus.EventBus;
import com.google.inject.assistedinject.Assisted;
import com.google.inject.assistedinject.AssistedInject;
import org.graylog2.inputs.random.generators.FakeHttpRawMessageGenerator;
+import org.graylog2.plugin.LocalMetricRegistry;
import org.graylog2.plugin.configuration.Configuration;
import org.graylog2.plugin.configuration.ConfigurationRequest;
import org.graylog2.plugin.configuration.fields.ConfigurationField;
@@ -56,8 +57,8 @@ public class RandomMessageTransport extends GeneratorTransport {
private final ObjectMapper objectMapper;
@AssistedInject
- public RandomMessageTransport(@Assisted Configuration configuration, EventBus eventBus, ObjectMapper objectMapper) {
- super(eventBus, configuration);
+ public RandomMessageTransport(@Assisted Configuration configuration, EventBus eventBus, ObjectMapper objectMapper, LocalMetricRegistry localMetricRegistry) {
+ super(eventBus, configuration, localMetricRegistry);
this.objectMapper = objectMapper;
generator = new FakeHttpRawMessageGenerator(configuration.getString(CK_SOURCE));
diff --git a/graylog2-server/src/main/java/org/graylog2/plugin/inputs/transports/GeneratorTransport.java b/graylog2-server/src/main/java/org/graylog2/plugin/inputs/transports/GeneratorTransport.java
index e3fd333c3..56e17488a 100644
--- a/graylog2-server/src/main/java/org/graylog2/plugin/inputs/transports/GeneratorTransport.java
+++ b/graylog2-server/src/main/java/org/graylog2/plugin/inputs/transports/GeneratorTransport.java
@@ -16,10 +16,12 @@
package org.graylog2.plugin.inputs.transports;
+import com.codahale.metrics.Gauge;
import com.codahale.metrics.MetricSet;
import com.google.common.util.concurrent.AbstractExecutionThreadService;
import com.google.common.util.concurrent.Service;
import org.graylog2.plugin.inputs.MessageInput;
import org.graylog2.plugin.inputs.MisfireException;
@@ -28,13 +30,29 @@ import org.graylog2.plugin.journal.RawMessage;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
+import java.security.NoSuchAlgorithmException;
+import java.security.SecureRandom;
public abstract class GeneratorTransport extends ThrottleableTransport {
private static final Logger log = LoggerFactory.getLogger(GeneratorTransport.class);
+ private final LocalMetricRegistry localMetricRegistry;
+ private final Gauge<Long> someGauge;
private Service generatorService;
- public GeneratorTransport(EventBus eventBus, Configuration configuration) {
+ public GeneratorTransport(EventBus eventBus, Configuration configuration, LocalMetricRegistry localMetricRegistry) {
+ this.localMetricRegistry = localMetricRegistry;
+ someGauge = localMetricRegistry.register("someGauge", new Gauge<Long>() {
+ @Override
+ public Long getValue() {
+ try {
+ return SecureRandom.getInstanceStrong().nextLong();
+ } catch (NoSuchAlgorithmException e) {
+ return 0L;
@Override
@@ -78,7 +96,7 @@ public abstract class GeneratorTransport extends ThrottleableTransport {
@Override
public MetricSet getMetricSet() {
- return null;
+ return localMetricRegistry;
