Hi, is the beat plugin working properly for metricbeat in 2.2.2?
When I send data with metricbeat 5.1.1 I get metric_system_process_cpu_total_pct reported as .50 instead of 50?
Best regards Mattias
That’s the correct value.
The percentage fields are a scaled floating point number between 0.0 (0%) and 1.0 (100%), see System Fields | Metricbeat Reference [5.1] | Elastic for details.
Wow that was really fast! Thank you for your reply.
