Logging stops when I check "Do not add Beats type as prefix" on Beats input config
I have this weird issue where if I enable the setting “Do not add Beats type as prefix”, logs will stop for the input where I configured it. I verified it by looking for new logs on the search tab.
As soon as I disable the feature, new logs starts showing up. Has anyone experienced this before?
This setting used to work previously without this problem.
he @v4rys
what kind of additional processing did you do? This might be a reason for this. That you have some processing that is looking into the field names and does not work when you remove them?
