Log Parsing and Analysis
I’m using a UDP input to ingest a single log file from an Ubuntu server. The log entries look like this:
2026-03-30T16:17:16.528Z monitoring-agent ‘_er.16.expired.broken.mydomain.com.7._er.agent.mydomain.net/IN’
The input works, and the log is ingested, but now I’d like to be able to analyze the entries. I’d like to be able to parse the log entries into three fields: timestamp, agent name, and report string. I’d like to be able to search all three of these fields for matching log entries. I’ve read as much documentation as I can find, but I’m still unsure of how to proceed. I’ve created a stream, but it has no rules. How can I parse and analyze records from this log?
  • OS Information: Ubuntu 24.04.4 LTS
  • Package Version: Graylog Open 7.0.6-1
I’ve created a stream, but I’m unsure of how to add the needed rules.
Describe how to parse the log entries and analyze the fields.
Hey @SAH62,
This course would help give you an understanding of how pipelines and rules can be used to parse/normalise your logs. Specifically you would be looking to use the grok or regex functions within the rules editor.
