Input statistic issue with pipeline
(Charles Deng) #1
there is no input statistic shows with pipeline:
Firstly, I configure that pipline processor for a stream:
Secondly i have defined the stream with filters based on static fields added by gelf collector agents:
thirdly, i have defined the pipleline connected to the above stream:
but I got:
and when show received message of the input, i got nothing:
and when got nothing from sources:
but check output the index set, there does have something but very little compare to the input rate:
Is there anything i do wrongly?
(Jochen) #2
You’ll have to provide more details if you want anybody to be able to help you.
  • Complete stream configuration
  • Complete stream rules
  • Complete pipeline rules used in that stage
  • Example messages
(Charles Deng) #3
sorry, i just change the x-pack to search guard those days just because of x-pack 30 days trial expired. after get this done, i try a carefully checking, i found there are some field names in the stream rule are not matched in the one sent by the collector. corrected it and fixed this issue.
(system) closed #4
