Infinity loading Screen for Collector Configuration
(Joshua Humpich) #1
I made some bigger Collector Configuration for my system.
At the end of configuration I noticed when I’m saving a new Input (in sum there where about 30) I doesn’t been shown in the Inputs listing.
First I thought they’re not all been shown or somethings but when I left the screen and retuned I get just a loading screen and nothing happend from here.
System Info:
Graylog Version 2.0.2
Elastic Search Version 2.3.3
MongoDB Version 3.0.14
Thanks for help,
Josh
(Jochen) #2
Hi Josh,
which version of the Graylog Collector plugin are you using?
How did you install and configure Graylog?
Are there any error messages in the logs of your Graylog node(s) or the Developer Console of your web browser?
Also make sure to upgrade to the latest stable version of Graylog (2.2.2 at the time of writing) and check if the problem still exists there.
