Hello. On the tab with alerts, constant loading. How can I find out what the problem is and fix it? There is nothing in the logs.
In web console on this page i see:
and this:
Based on your screenshot, in particular, this bit:
I’d start by trying to rebuild your index ranges. You can issue a blanket recalculation command using:
curl -u admin -X POST 'http://localhost:9000/api/system/indices/ranges/rebuild' -H "X-Requested-By: cli"
Which should help. Let me know how you get along with it.
Yeah. Is solved my problem, thanks!!!
