Hi all, since my graylog datanode disk full, I had add some new nodes, and my cluster has enough disk space now. But my Open Search cluster still in yellow state, like this:
OpenSearch cluster datanode-cluster is yellow. Shards: 3985 active, 0 initializing, 0 relocating, 8 unassigned
I had checkd the unassigned shades, got this:
[root@graylog-data1 ~]# curl -k -XGET “https://1.1.1.1:9200/_cat/shards?v&h=index,shard,prirep,state,unassigned.reason” --cert /root/cert/client.crt --key /root/cert/client.key --cacert /root/cert/ca.crt | grep UNAS
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0.opendistro_security 0 r UNASSIGNED REPLICA_ADDED
.opendistro_security 0 r UNASSIGNED NODE_LEFT
100 218k 100 218k 0 0 1086k 0 --:–:-- --:–:-- --:–:-- 1086k
.plugins-ml-config 0 r UNASSIGNED REPLICA_ADDED
.plugins-ml-config 0 r UNASSIGNED NODE_LEFT
Seems two shards, .plugins-ml-config and .opendistro_security are in UNASSIGNED state. But my cluster had enoungh disk space, maybe I should do somthing to the two shards?
So, how can I solve this to make my cluster to green? Thanks
