How to configure multiple beats input for various applications?
I am using 2.4.6 graylog and installed collector-sidecar on some another server. For single configuration where only one beat input/output works! but when i add one more beats input it throws one warning but older one is still working.
    ubuntu@ip-172-50-50-52:~$ sudo tail -f /var/log/graylog/collector-sidecar/filebeat
2018-08-14T10:46:17Z INFO Loading registrar data from /var/cache/graylog/collector-sidecar/filebeat/data/registry
2018-08-14T10:46:17Z INFO States Loaded from registrar: 3
2018-08-14T10:46:17Z WARN Filebeat is unable to load the Ingest Node pipelines for the configured modules because the Elasticsearch output is not configured/enabled. If you have already loaded the Ingest Node pipelines or are using Logstash pipelines, you can ignore this warning.
2018-08-14T10:46:17Z INFO Loading Prospectors: 2
2018-08-14T10:46:17Z INFO Starting Registrar
2018-08-14T10:46:17Z INFO Starting prospector of type: log; ID: 9751877527429249501
2018-08-14T10:46:17Z INFO Starting prospector of type: log; ID: 644587000511631764
2018-08-14T10:46:17Z INFO Loading and starting Prospectors completed. Enabled prospectors: 2
2018-08-14T10:46:27Z INFO Harvester started for file: /home/ubuntu/spock-core/log/spock-access.log
2018-08-14T10:46:47Z INFO Non-zero metrics in the last 30s: beat.info.uptime.ms=30002 beat.memstats.gc_next=5878576 beat.memstats.memory_alloc=4516208 beat.memstats.memory_total=12882288 filebeat.events.active=2 filebeat.events.added=110 filebeat.events.done=108 filebeat.harvester.open_files=1 filebeat.harvester.running=1 filebeat.harvester.started=1 libbeat.config.module.running=0 libbeat.output.events.acked=106 libbeat.output.events.batches=6 libbeat.output.events.total=106 libbeat.output.read.bytes=36 libbeat.output.type=logstash libbeat.output.write.bytes=7810 libbeat.pipeline.clients=2 libbeat.pipeline.events.active=2 libbeat.pipeline.events.filtered=2 libbeat.pipeline.events.published=108 libbeat.pipeline.events.retry=92 libbeat.pipeline.events.total=110 libbeat.pipeline.queue.acked=106 registrar.states.current=3 registrar.states.update=108 registrar.writes=8
refer below details :slight_smile:
  1. is it not working?
  2. did you read the WARN until the end?
@jan
First configured beats input is working.
Second input is not working and also getting “WARN” ->
Also, can you please educate me how to fetch multiple application logs through filebeat-collector from same server.
Options:
  1. creating mupliple beats input for one beats output.
  2. seprate collector-configuration for every new application logs.
@jan
— SOLVED----
So, I figured out that graylog automatically genrates filebeat configuration when we add additional beats input with same beats output and on same input through graylog collector.
