How do you process and analyze Graylog’s own logs (for all the cluster components)?
Hi @Tiger,
We do highly not recommend that a cluster does analyze its own logs, since the can lead to chain reactions like: One log message produces an error, which produces a log message in the cluster which itself produces an error.
If you really want to analyze the graylog logs in a graylog, I would guess you could start a single node graylog instance NOT connected to that cluster. But I am not so sure if this is so helpful.
I hope this answers your question.
Best regards,
Konrad
Thanks. It makes cense
