Graylog with graysquid module
hello,
I installed the graysquid module on graylog to receive logs from squid.
I followed this guide : https://github.com/yon2004/GraySquid
but when i use the command : “service rsyslog status”, i have this :
juin 25 09:30:00 PROXY-CAEC-CADES systemd[1]: Starting System Logging Service…
juin 25 09:30:00 PROXY-CAEC-CADES rsyslogd[3476]: [origin software=“rsyslogd” swVersion=“8.24.0” x-pid=“3476” x-info=“http://www.rsyslog.com”] start
juin 25 09:30:00 PROXY-CAEC-CADES rsyslogd[3476]: could not load module ‘/usr/lib64/rsyslog/omfwd.so’, dlopen: /usr/lib64/rsyslog/omfwd.so: cannot open shared object file: No such file or directory [v8.24.0 try http://www.rsyslog.com/e/2066 ]
juin 25 09:30:00 PROXY-CAEC-CADES systemd[1]: Started System Logging Service.
juin 25 09:30:00 PROXY-CAEC-CADES rsyslogd[3476]: action ‘action 1’ suspended, next retry is Mon Jun 25 09:30:30 2018 [v8.24.0 try http://www.rsyslog.com/e/2007 ]
Thanks you by advance for your time
juin 25 09:30:00 PROXY-CAEC-CADES rsyslogd[3476]: could not load module ‘/usr/lib64/rsyslog/omfwd.so’, dlopen: /usr/lib64/rsyslog/omfwd.so: cannot open shared object file: No such file or directory [v8.24.0 try You searched for error 2066 - rsyslog ]
you are missing a needed module for the configuration. Add this module to rsyslog and it will work.
Yes,
but i don’t know how to add a module, is there a tutorial or something like this ?
I googled it but didn’t found enough information.
that would be something the rsyslog community can help you better with.
