looking for zenoss integration options for the alarm data. Do we have any plugin available to send alarm data on zenoss’s desired format.
you might find some in the marketplace:
Thanks Jan for your replay ,…
could not find the plugin for the same , any Road map for zenoss integration
not from a company perspective - maybe you can find other persons that are intereseted in that and build the integration. This is a free software product you can customize with plugins.
regards
Jan
