I am running some Graylog instances to receive data from various sources, process them via pipelines and various extractors and send them to other components/dashboards via stream outputs (mainly transparent).
I’d like to know how does Graylog output react to indexing failures (e.g. when the available disk space is lower than a minimum threshold, and further indexing is blocked by ES read-only policy).
Is the output forwarding process performed regardless of the indexing process ? Or, does the output forwarding blocks in case of a read-only index?
Thanks for the help!
