Graylog Pod Failing to connect to Opensearch due to TLS error
I am setting up Graylog and Opensearch using Helm on a kubernetes cluster. Opensearch is running with TLS configured. I have generated a JAVA jks which i have imported into the graylog pod so as to established a trusted source, but i am still getting error “java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty”
  • OS Information:
    Nodes OS: Centos 8
    Platform Kubernetes v1.24.8
    Helm version v3.12.2
  • Package Version:
    Graylog 5.0.3
Graylog Pod Logs:
javax.net.ssl|ERROR|10|main|2024-01-23 05:11:01.531 UTC|null:-1|Fatal (INTERNAL_ERROR): Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty (
“throwable” : {
at java.base/sun.security.validator.PKIXValidator.(Unknown Source)
at java.base/sun.security.validator.Validator.getInstance(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.getValidator(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrustedInit(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.onConsumeCertificate(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.consume(Unknown Source)
at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source)
at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:336)
at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:300)
at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:185)
at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.java:224)
at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.java:108)
at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.java:88)
at okhttp3.internal.connection.Transmitter.newExchange(Transmitter.java:169)
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:41)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117)
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94)
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88)
at org.graylog2.storage.versionprobe.VersionProbe.lambda$addAuthenticationIfPresent$3(VersionProbe.java:154)
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229)
at okhttp3.RealCall.execute(RealCall.java:81)
at retrofit2.OkHttpCall.execute(OkHttpCall.java:204)
at org.graylog2.storage.versionprobe.VersionProbe.rootResponse(VersionProbe.java:174)
at org.graylog2.storage.versionprobe.VersionProbe.probeSingleHost(VersionProbe.java:137)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.tryAdvance(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.forEachWithCancel(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyIntoWithCancel(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.FindOps$FindOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.findFirst(Unknown Source)
at org.graylog2.storage.versionprobe.VersionProbe.probeAllHosts(VersionProbe.java:107)
at org.graylog2.storage.versionprobe.VersionProbe.lambda$probe$1(VersionProbe.java:95)
at com.github.rholder.retry.AttemptTimeLimiters$NoAttemptTimeLimit.call(AttemptTimeLimiters.java:78)
at com.github.rholder.retry.Retryer.call(Retryer.java:160)
at org.graylog2.storage.versionprobe.VersionProbe.probe(VersionProbe.java:95)
at org.graylog2.bootstrap.preflight.SearchDbPreflightCheck.runCheck(SearchDbPreflightCheck.java:50)
at com.google.common.collect.ImmutableList.forEach(ImmutableList.java:422)
at org.graylog2.bootstrap.preflight.PreflightCheckService.runChecks(PreflightCheckService.java:51)
at org.graylog2.bootstrap.ServerBootstrap.runPreFlightChecks(ServerBootstrap.java:153)
at org.graylog2.bootstrap.ServerBootstrap.beforeInjectorCreation(ServerBootstrap.java:138)
at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:304)
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:260)
at org.graylog2.bootstrap.Main.main(Main.java:45)
Caused by: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at java.base/java.security.cert.PKIXParameters.setTrustAnchors(Unknown Source)
at java.base/java.security.cert.PKIXParameters.(Unknown Source)
at java.base/java.security.cert.PKIXBuilderParameters.(Unknown Source)
Graylog Values YAML:
I have tried to run an init Container so as to change the ownership of the trustore file to use graylog user as below but cant make a breakthrough. When i ssh into pod he file is still owned by root user instead of graylog user
init:
## Init Container image
#image:
# repository: “alpine”
# pullPolicy: “IfNotPresent”
#command:
#- chown
#- -R
#- graylog:graylog
#- /usr/share/graylog/os-cacerts.jks
Kindly assist on how i can solve these issues, how can I successfuly connect Graylog Pod to Openserarch using helm charts
Default values for Graylog.
This is a YAML-formatted file.
Declare variables to be passed into your templates.
rbac:
Specifies whether RBAC resources should be created
create: true
resources:
- pods
- secrets
serviceAccount:
Specifies whether a ServiceAccount should be created
create: true
The name of the ServiceAccount to use.
If not set and create is true, a name is generated using the fullname template
name:
Service Account annotations
annotations: {}
tags:
If true, this chart will install opensearch from requirement dependencies
install-opensearch: false
If true, this chart will install MongoDB replicaset from requirement dependencies
install-mongodb: true
Enable only if your current release was migrated from helm2 (using 2to3 plugin).
Because Kubernetes considers some StatefulSets fields/labels immutable,
this flag preserves the values rendered by helm2. This allows helm3
to upgrade the current release without a complete purge/reinstall.
helm2Compatibility: true
Specify image pull secrets used in the deployment
imagePullSecrets:
imagePullSecrets:
- name: some-registry
- name: another-registry
graylog:
Graylog image version
Important note: Official Graylog Docker image may replace the existing Docker image tags and cause some corrupt when starting the pod.
Make sure you strict with the x version of Graylog where x is ${version}-${x}
image:
repository: “graylog/graylog”
tag: “5.0.3”
Graylog default Java option
javaOpts: “-Dlog4j2.formatMsgNoLookups=true -Djdk.tls.acknowledgeCloseNotify=true -XX:+UnlockExperimentalVMOptions -XX:-OmitStackTraceInFastThrow -XX:+UseG1GC -server”
javaOpts: “-Dlog4j2.formatMsgNoLookups=true -Djdk.tls.acknowledgeCloseNotify=true -XX:+UnlockExperimentalVMOptions -XX:-OmitStackTraceInFastThrow -XX:+UseG1GC -Djavax.net.debug=all -Djavax.net.ssl.trustStore=/usr/share/graylog/os-cacerts.jks -server”
#javaOpts: “-Dlog4j2.formatMsgNoLookups=true -Djdk.tls.acknowledgeCloseNotify=true -XX:+UnlockExperimentalVMOptions -XX:-OmitStackTraceInFastThrow -XX:+UseG1GC -server”
Number of Graylog instance
replicas: 1
Additional environment variables to be added to Graylog pods
env:
#- name: SKIP_PREFLIGHT_CHECK
#value: true
Additional labels to be added to Graylog pods
customLabels: {}
Additional environment variables in raw yaml format
- name: POD_IP
valueFrom:
fieldRef:
fieldPath: status.podIP
- name: SERVICE_8000_NAME
value: servicename
envRaw: {}
Pod affinity
affinity: {}
Node tolerations for node-exporter scheduling to nodes with taints
tolerations:
# - key: “key”
# operator: “Equal|Exists”
# value: “value”
# effect: “NoSchedule|PreferNoSchedule|NoExecute(1.6 only)”
Node labels for node-exporter pod assignment
nodeSelector: {}
Annotations to be added to Graylog pods
podAnnotations: {}
If specified, indicates the pod’s priority.
priorityClassName:
Set security context for defining privilege and accessing control settings entire Pod
podSecurityContext:
# runAsUser: 10001
# fsGroup: 65534
Set security context for defining privilege and accessing control settings for Graylog container
securityContext:
privileged: false
# capabilities:
# drop:
# - ALL
# readOnlyRootFilesystem: true
# runAsNonRoot: true
# runAsUser: 1000
persistence:
## If true, Graylog will create/use a Persistent Volume Claim
## If false, use emptyDir
enabled: true
## Graylog data Persistent Volume access modes
## Must match those of existing PV or dynamic provisioner
accessMode: ReadWriteOnce
## Graylog data Persistent Volume size
## Graylog data Persistent Volume Storage Class
## If defined, storageClassName:
## If set to “-”, storageClassName: “”, which disables dynamic provisioning
## If undefined (the default) or set to null, no storageClassName spec is
## set, choosing the default provisioner. (gp2 on AWS, standard on
## GKE, AWS & OpenStack)
# storageClass: “ssd”
Additional plugins you need to install on Graylog.
plugins:
## If true, set proxy server to retrieve the plugins
proxy:
enabled: false
host:
locations: []
Sidecar containers
sidecarContainers:
Additional init containers
extraInitContainers:
#- name: volume-permissions
#image: busybox
#command: [“sh”, “-c”, “chown -R 1100:1100 /usr/share/graylog/os-cacerts.jks”]
#volumeMounts:
#- name: my-config-volume
# mountPath: /usr/share/graylog/
Additional volume mounts
extraVolumeMounts:
mountPath: /usr/share/graylog/os-cacerts.jks
subPath: os-cacerts.jks
readOnly: false
Additional volumes
extraVolumes:
configMap:
A service for Graylog web interface
service:
type: NodePort
port: 9000
## Add additional ports for the service/statefulset to expose
ports:
headless:
  ## Add suffix to headless service name
  suffix: ""
master:
  ## Enable Graylog master service
  enabled: true
  ## Graylog master service Ingress annotations
  annotations: {}
  ## Graylog master service port.
  port: 9000
  ## Graylog master service type.
  type: ClusterIP
startupProbe:
periodSeconds: 60
failureThreshold: 3
successThreshold: 1
timeoutSeconds: 5
livenessProbe:
initialDelaySeconds: 0
periodSeconds: 30
failureThreshold: 3
successThreshold: 1
timeoutSeconds: 5
readinessProbe:
periodSeconds: 10
failureThreshold: 3
successThreshold: 1
timeoutSeconds: 5
Additional input ports for receiving logs from servers
Note: Name must be in IANA_SVC_NAME (at most 15 characters, matching regex a-z0-9* and it must contains at least one letter [a-z], hyphens cannot be adjacent to other hyphens)
Note: Array must be sorted by port order
input:
# tcp:
# service:
# name: your-tcp-service-name
# type: LoadBalancer
# loadBalancerIP:
# ports:
# - name: gelf
# port: 12222
# udp:
# service:
# name: your-udp-service-name
# type: ClusterIP
# ports:
# - name: syslog
# port: 12222
tls:
## If true, Graylog server will run with TLS enabled
enabled: false
## TLS certificate key file
keyFile: /etc/graylog/server/server.key
## TLS certificate file
certFile: /etc/graylog/server/server.cert
externalUri: “”
ingress:
## If true, Graylog server Ingress will be created
enabled: false
## Graylog server Ingress annotations
annotations: {}
## Graylog server Ingress labels
labels: {}
# labels:
#  traffic-type: public
## Specify the Ingress class name
ingressClassName: ""
## Graylog server Ingress hostnames with optional path
## Must be provided if Ingress is enabled
## Note: Graylog does not support two URL. You can specify only single URL
hosts: []
#  - graylog.yourdomain.com
## Extra paths to prepend to every host configuration. This is useful when working with annotation based services.
extraPaths: []
# - path: /*
#   backend:
#     serviceName: ssl-redirect
#     servicePort: use-annotation
## Graylog server Ingress TLS configuration
## Secrets must be manually created in the namespace
tls: []
#   - secretName: graylog-server-tls
#     hosts:
## For Kubernetes 1.18 or later. Use Prefix or Exact path types.
pathType: Prefix
## An URL path
path: /
istio:
## If true, Graylog server Istio Ingress Gateway will be created
enabled: false
## Change if you use custom ingressgateway controller
gatewaySelector:
  istio: ingressgateway
## Graylog server Istio Ingress Gateway hostnames with optional path
#host: []
## Please note that tls secret should reside in istio-system namespace
## leave blanc for disabling TLS
tlsSecretName: ""
Configure resource requests and limits
resources:
limits:
cpu: “1”
requests:
cpu: “300m”
memory: “1000Mi”
Set Graylog Java heapsize. If this value empty, chart will allocate heapsize using -XX:+UseCGroupMemoryLimitForHeap
heapSize: “16g”
RollingUpdate update strategy
updateStrategy: RollingUpdate
Control the maximum number of Pods that can be unavailable during an update
maxUnavailable: 10%
Graylog server pod termination grace period
terminationGracePeriodSeconds: 120
metrics:
## If true, prometheus annotations will be attached
enabled: false
serviceMonitor:
enabled: false
additionalLabels: {}
scrapeTimeout: 10s
interval: 10s
geoip:
## If true, Maxmind GeoLite2 will be installed to ${GRAYLOG_HOME}/geoip location
enabled: false
mmdbUri: “”
Graylog root user name
rootUsername: “admin”
Graylog root password
Defaults to a random 16-character alphanumeric string if not set
rootPassword: “”
Graylog root email
rootEmail: “”
Graylog root timezone
rootTimezone: “UTC”
Grayog existing root secret
existingRootSecret: “”
opensearch:
## Major version of the Elasticsearch version used.
# version: "7"
## List of Elasticsearch hosts Graylog should connect to.
## Need to be specified as a comma-separated list of valid URIs for the http ports of your elasticsearch nodes.
## If one or more of your elasticsearch hosts require authentication, include the credentials in each node URI that
## requires authentication.
hosts: https://admin:admin@opensearch-cluster-master-headless.graylog.svc.cluster.local:9200
# Allow elasticsearch hosts to be fetched from a k8s secret
# {{ graylog.fullname }}-es will be used as uriSecretName if left empty
uriSecretName: ""
uriSecretKey: ""
uriSSL: false
mongodb:
## MongoDB connection string
# uri: mongodb://user:pass@host1:27017,host2:27017,host3:27017/graylog?replicaSet=rs01
uri: “”
# Allow mongodb uri to be fetched from a k8s secret
# {{ graylog.fullname }}-headless will be used as uriSecretName if left empty
uriSecretName: “”
uriSecretKey: “”
## Increase this value according to the maximum connections your MongoDB server can handle from a single client
## if you encounter MongoDB connection problems.
maxConnections: 1000
transportEmail:
## If true, enable Email transport.
enabled: false
hostname: “”
port: 2587
useAuth: true
useTls: true
useSsl: false
authUsername: “”
authPassword: “”
subjectPrefix: “[graylog]”
fromEmail: “”
Additional graylog config which is defined on graylog.conf.
Graylog config is written in Java properites format. Make sure you write it correctly.
config: |
elasticsearch_connect_timeout = 10s
elasticsearch_socket_timeout = 60s
elasticsearch_idle_timeout = -1s
journal:
## Sometime Graylog journal continually grow up or corrupt and cause Graylog unable to start.
## You need to clean up all journal files in order to run the Graylog.
## Change graylog.journal.deleteBeforeStart to true to delete all journal files before start
## Note: All uncommitted logs will be permanently DELETED when this value is true
deleteBeforeStart: false
## Maximum size of the graylog journal.
maxSize: 5gb
init:
#image:
#command:
#- chown
#- -R
#- graylog:graylog
# kubectlVersion: "v1.20"
# Additional environment variables to be added to Graylog initContainer
env: {}
# Configure resource requests and limits for the Graylog StatefulSet initContainer
resources: {}
Additional server files will be deployed to /etc/graylog/server
For example, you can put server certificates or authorized clients certificates here
serverFiles:
 server.key: |
   -----BEGIN PRIVATE KEY-----
   xxxx
   -----END PRIVATE KEY-----
 server.cert: |
   -----BEGIN CERTIFICATE-----
  xxx
   -----END CERTIFICATE-----
Configure whether Graylog pods should log in JSON (one event per line)
logInJson: false
Specify a Bash script to run as Kubernetes Job (running on Alpine with curl and bash packages already installed).
Useful for calling the API to pre-configure some aspect of Graylog, as in the example.
provisioner:
enabled: false
annotations: {}
useGraylogServiceAccount: false
# script: |
# json=‘{
# “username_header”: “X-Auth-Request-User”,
# “fullname_header”: “X-Auth-Request-User”,
# “email_header”: “X-Auth-Request-Email”,
# “default_group”: “Admin”,
# “auto_create_user”: true,
# “require_trusted_proxies”: true,
# “trusted_proxies”: “0.0.0.0/0”,
# “default_email_domain”: “mydomain.com”,
# “sync_roles”: false,
# “roles_header”: “Roles”
# curl -v -u “admin:$GRAYLOG_PASSWORD_SECRET” -X PUT --header ‘Content-Type: application/json’ --header ‘X-Requested-By: localhost’ --data-binary “${json}”
## Additional environment variables to be added to Graylog provisioner job
env: {}
## Additional environment variables in raw yaml format
## - name: POD_IP
##   valueFrom:
##     fieldRef:
##       fieldPath: status.podIP
## - name: SERVICE_8000_NAME
##   value: servicename
envRaw: {}
secret:
## Secret annotations
annotations: {}
options:
## Using search result highlighting will result in slightly higher resource consumption of searches.
allowHighlighting: false
## Do you want to allow searches with leading wildcards?
## This can be extremely resource hungry and should only be enabled with care.
allowLeadingWildcardSearches: false
## Size of internal ring buffers.
## Must be a power of 2. (512, 1024, 2048, …)
ringSize: ""
inputBufferRingSize: ""
## The threshold of the garbage collection runs. If GC runs take longer than this
## threshold, a system notification will be generated to warn the administrator
## about possible problems with the system. Default is 1 second.
gc_warning_threshold: 1s
## Buffer processor settings.
## A good rule of thumb is to never go over the number of cores available
outputbufferProcessors: 3
inputbufferProcessors: 2
processbufferProcessors: 5
opensearch:
enabled: false
extraEnvs:
- name: plugins.security.ssl.http.enabled
value: “false”
- name: plugins.security.disabled
value: “true”
- name: OPENSEARCH_JAVA_OPTS
value: “-Xms512m -Xmx512m”
- “OPENSEARCH_JAVA_OPTS=-Xms512m -Xmx512m”
- “discovery.seed_hosts=opensearch2,opensearch3”
- “cluster.initial_master_nodes=opensearch1,opensearch2,opensearch3”
- “bootstrap.memory_lock=true”
- “action.auto_create_index=false”
resources:
requests:
cpu: “100m”
memory: “512M”
limits:
cpu: “1000m”
memory: “512M”
volumeClaimTemplate:
resources:
requests:
storage: 30Gi # default 30Gi
Specify Mongodb settings. Ignore this section if you install MongoDB manually.
mongodb:
architecture: “replicaset”
useStatefulSet: true
replicaCount: 1
auth:
enabled: false
Here’s another post involving missing trustanchor which might be helpful:
