Graylog Login Page Issue
I have deployed Graylog version 6.1.2 along with OpenSearch, which is compatible with Graylog. However, the login page is not loading. Interestingly, when I perform port forwarding, the login page works fine. The error shown is: “Loading active authentication service type failed.” Upon checking the logs, there are no significant entries related to this issue.
  • OS Information:
    Distributor ID: Debian
    Description: Debian GNU/Linux 12 (bookworm)
    Release: 12
    Codename: bookworm
  • Package Version:
    Graylog: 6.1.2
    I checked the logs but did not find any significant entries related to the authentication service issue. Configurations seem correct, and environment variables were set as per the documentation.
  • Verified that OpenSearch is compatible with Graylog version 6.1.2.
  • Checked the logs for any errors or significant issues but found none related to the authentication service.
  • Ensured that port forwarding allows the login page to work as expected.
  • Confirmed that the deployment setup adheres to Graylog and OpenSearch guidelines.
  • Help identify why the login page does not load without port forwarding.
  • Suggest further troubleshooting steps or configuration checks that might resolve the “Loading active authentication service type failed” error.
  • Provide insights into potential network or service misconfigurations that could cause this behavior
