Throws an error message if I create a secured mongodb instance with a custom port number rather than the default which has open access.
Can connect to the Mongo instance manually
Graylog can’t connect to Mongo Auth with Custom Port even when set in graylog.conf
graylog | 2020-09-06 15:14:09,623 INFO : org.mongodb.driver.cluster - Exception in monitor thread while connecting to server localhost:9995
graylog | com.mongodb.MongoSocketOpenException: Exception opening socket
graylog | at com.mongodb.internal.connection.SocketStream.open(SocketStream.java:70) ~[graylog.jar:?]
graylog | at com.mongodb.internal.connection.InternalStreamConnection.open(InternalStreamConnection.java:128) ~[graylog.jar:?]
graylog | at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:117) [graylog.jar:?]
graylog | at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
graylog | Caused by: java.net.ConnectException: Connection refused (Connection refused)
graylog | at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_265]
graylog | at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_265]
graylog | at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_265]
graylog | at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_265]
graylog | at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_265]
graylog | at java.net.Socket.connect(Socket.java:607) ~[?:1.8.0_265]
graylog | at com.mongodb.internal.connection.SocketStreamHelper.initialize(SocketStreamHelper.java:64) ~[graylog.jar:?]
graylog | at com.mongodb.internal.connection.SocketStream.initializeSocket(SocketStream.java:79) ~[graylog.jar:?]
graylog | at com.mongodb.internal.connection.SocketStream.open(SocketStream.java:65) ~[graylog.jar:?]
graylog | … 3 more
