Graylog 2.4 rc2 Slack Alarm going to 'resolved' status automatically
Hi All,
I have a Graylog server running the last 2.4 rc-2 software with integration into a Slack channel.
The alarms are being received and work with Slack fine.
However, as soon as the alarm is received by Slack, Graylog marks it as ‘resolved’. I want to leave it in an unresolved state till someone acknowledges it.
Is this a configuration option that I am missing
Cheers
Jake
the alert will re resolved if the next search does not return the condition.
It might be a bug in the slack plugin and you should report that as an issue in the Plugin repository.
Hi Jan,
First , I will retry with upgrade to new release 2.4 as I am on a release candidate?
Then I will retry.
I will come back to you.
Jake
