I am trying to setup a logfwding to GELF with fluentBit and enable TLS.
I did the following:
- Created self signed certs and key
- Updated server.conf as mentioned in the doc
- Created a GELF tcp input ()
- On the fluentBit side i enabled the tls.verify and tls.ca with the CA file i used to sign the server cert.
The flunetBit logs says API server connectivity ok , but the logs never reach GELF.
[2020/05/29 13:30:37] [ info] [filter:kubernetes:kubernetes.0] https=1 host=kubernetes.default.svc port=443
[2020/05/29 13:30:37] [ info] [filter:kubernetes:kubernetes.0] local POD info OK
[2020/05/29 13:30:37] [ info] [filter:kubernetes:kubernetes.0] testing connectivity with API server...
[2020/05/29 13:30:37] [ info] [filter:kubernetes:kubernetes.0] API server connectivity OK
[2020/05/29 13:30:37] [ info] [sp] stream processor started
If i disable tls , things work fine.
Any help would be much appreciated.
