Hello to all! I need to find the query (url) with the most 500 errors. How can I set the search mask to find the largest query with this query parameter?
nobody can help you with that - without the knowledge how you data is normalized and what fields are available.
If you have URL and RETURNCODE in two fields, you can create a search on the Returncode and then a quick values on the URL … just as idea.
