my original file;
#!/bin/bash
export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
if [ -z "$1" ]; then
ADAYAGO=`date --date="1 day ago" +%Y-%m-%d`
else
ADAYAGO="$1"
fi
echo "Starting $ADAYAGO"
QUERY_STR='{"query":{"range":{"timestamp":{"gte":"'"$ADAYAGO "'00:00:00.000","lte":"'"$ADAYAGO"' 23:59:59.999"}}}}'
EXPORT_PATH=/home/sgeuser/elasticsearch
EXPORT_FILE_NAME=esbackup.$ADAYAGO.json
es-export-bulk --url http://localhost:9200 --file $EXPORT_PATH/$EXPORT_FILE_NAME --body "$QUERY_STR"
ls -lh $EXPORT_PATH/$EXPORT_FILE_NAME
gzip -9 $EXPORT_PATH/$EXPORT_FILE_NAME
md5sum $EXPORT_PATH/$EXPORT_FILE_NAME.gz > $EXPORT_PATH/$EXPORT_FILE_NAME.gz.hash
sha1sum $EXPORT_PATH/$EXPORT_FILE_NAME.gz >> $EXPORT_PATH/$EXPORT_FILE_NAME.gz.hash
sha256sum $EXPORT_PATH/$EXPORT_FILE_NAME.gz >> $EXPORT_PATH/$EXPORT_FILE_NAME.gz.hash
es-export-bulk --url http://localhost:9200 --file $EXPORT_PATH/$EXPORT_FILE_NAME --body “$QUERY_STR”
it gives an error
fs.js:646
return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
Error: EISDIR: illegal operation on a directory, open '/'
at Object.fs.openSync (fs.js:646:18)
at Object.fs.writeFileSync (fs.js:1299:33)
at Object.<anonymous> (/usr/local/lib/node_modules/elasticsearch-tools/lib/es-export-bulk.js:279:6)
at Module._compile (module.js:652:30)
at Object.Module._extensions..js (module.js:663:10)
at Module.load (module.js:565:32)
at tryModuleLoad (module.js:505:12)
at Function.Module._load (module.js:497:3)
at Function.Module.runMain (module.js:693:10)
at startup (bootstrap_node.js:188:16)
I am getting error while exporting
can you help?
