Hello everyone.
Im trying to develop a notification plugin, and I
m using the following plugins as a reference:
graylog-plugin-teams
TelegramAlert
graylog-plugin-slack-notification
I setup a development environment, using the boostrap tutorial, and my current setup is in version 3.2.0-snapshot4.
I download the source code of the plugins, add them to my graylog-server , and they appear on my notificatiions menu. However, when I run the test notification, it does not trigger the event, and show me the this message.
Here is the browser console:
The logs in var/log/graylog-server show the following message:
2020-03-30T20:58:54.059Z INFO [ServerBootstrap] Services started, startup times in ms: {InputSetupService [RUNNING]=7, GracefulShutdownService [RUNNING]=7, JournalReader [RUNNING]=25, KafkaJournal [RUNNING]=25, BufferSynchronizerService [RUNNING]=41, UrlWhitelistService [RUNNING]=41, OutputSetupService [RUNNING]=49, JobSchedulerService [RUNNING]=52, EtagService [RUNNING]=70, ConfigurationEtagService [RUNNING]=93, MongoDBProcessingStatusRecorderService [RUNNING]=103, StreamCacheService [RUNNING]=176, LookupTableService [RUNNING]=186, PeriodicalsService [RUNNING]=194, JerseyService [RUNNING]=25970}
2020-03-30T20:58:54.077Z INFO [ServerBootstrap] Graylog server up and running.
2020-03-30T20:58:54.077Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-03-30T21:00:46.471Z INFO [Server] SIGNAL received. Shutting down.
2020-03-30T21:00:46.478Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-03-30T21:00:46.478Z INFO [GracefulShutdown] Graceful shutdown initiated.
2020-03-30T21:00:46.478Z INFO [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
2020-03-30T21:00:50.513Z INFO [Buffers] Waiting until all buffers are empty.
2020-03-30T21:00:50.515Z INFO [Buffers] All buffers are empty. Continuing.
2020-03-30T21:00:50.518Z INFO [OutputSetupService] Stopping output org.graylog2.outputs.BlockingBatchedESOutput
2020-03-30T21:00:50.527Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread].
2020-03-30T21:00:50.527Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] complete, took <0ms>.
2020-03-30T21:00:50.527Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ClusterHealthCheckThread].
2020-03-30T21:00:50.527Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ClusterHealthCheckThread] complete, took <0ms>.
2020-03-30T21:00:50.527Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexerClusterCheckerThread].
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexerClusterCheckerThread] complete, took <0ms>.
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRetentionThread].
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRetentionThread] complete, took <0ms>.
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRotationThread].
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRotationThread] complete, took <0ms>.
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.VersionCheckThread].
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.VersionCheckThread] complete, took <0ms>.
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ThrottleStateUpdaterThread].
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ThrottleStateUpdaterThread] complete, took <0ms>.
2020-03-30T21:00:50.528Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventPeriodical].
2020-03-30T21:00:50.529Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventPeriodical] complete, took <0ms>.
2020-03-30T21:00:50.529Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventCleanupPeriodical].
2020-03-30T21:00:50.529Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventCleanupPeriodical] complete, took <0ms>.
2020-03-30T21:00:50.529Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical].
2020-03-30T21:00:50.529Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical] complete, took <0ms>.
2020-03-30T21:00:50.529Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.TrafficCounterCalculator].
2020-03-30T21:00:50.530Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.TrafficCounterCalculator] complete, took <0ms>.
2020-03-30T21:00:50.531Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical].
2020-03-30T21:00:50.531Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] complete, took <0ms>.
2020-03-30T21:00:50.531Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp].
2020-03-30T21:00:50.531Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] complete, took <0ms>.
2020-03-30T21:00:50.531Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread].
2020-03-30T21:00:50.531Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] complete, took <0ms>.
2020-03-30T21:00:50.531Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads].
2020-03-30T21:00:50.531Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] complete, took <0ms>.
2020-03-30T21:00:50.531Z INFO [GracefulShutdownService] Running graceful shutdown for <2> shutdown hooks
2020-03-30T21:00:50.531Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob].
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob] complete, took <0ms>.
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp].
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp] complete, took <0ms>.
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread].
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] complete, took <0ms>.
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.license.LicenseManagerPeriodical].
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.license.LicenseManagerPeriodical] complete, took <0ms>.
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.license.LicenseReportPeriodical].
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.license.LicenseReportPeriodical] complete, took <0ms>.
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.report.scheduler.ReportPeriodical].
2020-03-30T21:00:50.532Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.report.scheduler.ReportPeriodical] complete, took <0ms>.
2020-03-30T21:00:50.533Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical].
2020-03-30T21:00:50.533Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical] complete, took <0ms>.
2020-03-30T21:00:50.533Z INFO [GracefulShutdownService] Initiate shutdown for
2020-03-30T21:00:50.534Z INFO [GracefulShutdownService] Finished shutdown for , took 0 ms
2020-03-30T21:00:50.537Z INFO [GracefulShutdownService] Initiate shutdown for
2020-03-30T21:00:50.537Z INFO [GracefulShutdownService] Finished shutdown for , took 0 ms
2020-03-30T21:00:50.538Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-03-30T21:00:50.538Z INFO [GracefulShutdown] Goodbye.
2020-03-30T21:00:50.539Z INFO [JerseyService] Shutting down HTTP listener at <0.0.0.0:9000>
2020-03-30T21:00:50.540Z INFO [JournalReader] Stopping.
2020-03-30T21:00:50.568Z INFO [LookupDataAdapterRefreshService] Stopping 0 jobs
2020-03-30T21:00:50.562Z INFO [LogManager] Shutting down.
2020-03-30T21:00:50.602Z INFO [LogManager] Shutdown complete.
2020-03-30T21:00:50.614Z INFO [NetworkListener] Stopped listener bound to [0.0.0.0:9000]
2020-03-30T21:00:50.836Z INFO [ServiceManagerListener] Services are now stopped.
2020-03-30T21:00:54.241Z INFO [CmdLineTool] Loaded plugin: SNMPNotification 1.0.0 [SNMPNotificationPlugin]
2020-03-30T21:00:54.245Z INFO [CmdLineTool] Loaded plugin: TelegramNotification 2.3.1-SNAPSHOT [de.irgendwr.TelegramNotificationPlugin]
2020-03-30T21:00:54.247Z INFO [CmdLineTool] Loaded plugin: AWS plugins 3.2.4 [org.graylog.aws.AWSPlugin]
2020-03-30T21:00:54.248Z INFO [CmdLineTool] Loaded plugin: Enterprise Integrations 3.2.4 [org.graylog.enterprise.integrations.EnterpriseIntegrationsPlugin]
2020-03-30T21:00:54.249Z INFO [CmdLineTool] Loaded plugin: Integrations 3.2.4 [org.graylog.integrations.IntegrationsPlugin]
2020-03-30T21:00:54.250Z INFO [CmdLineTool] Loaded plugin: Collector 3.2.4 [org.graylog.plugins.collector.CollectorPlugin]
2020-03-30T21:00:54.252Z INFO [CmdLineTool] Loaded plugin: Graylog Enterprise 3.2.4 [org.graylog.plugins.enterprise.EnterprisePlugin]
2020-03-30T21:00:54.253Z INFO [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 3.2.4 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2020-03-30T21:00:54.640Z INFO [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:-OmitStackTraceInFastThrow -XX:+UseParNewGC -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2020-03-30T21:00:54.935Z INFO [Version] HV000001: Hibernate Validator null
2020-03-30T21:00:58.556Z INFO [InputBufferImpl] Message journal is enabled.
2020-03-30T21:00:58.584Z INFO [NodeId] Node ID: 0055c923-e395-4515-8c9c-4a625892dad7
2020-03-30T21:00:58.803Z INFO [LogManager] Loading logs.
2020-03-30T21:00:58.871Z INFO [LogManager] Logs loading complete.
2020-03-30T21:00:58.874Z INFO [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2020-03-30T21:00:58.893Z INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000}
2020-03-30T21:00:58.934Z INFO [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2020-03-30T21:00:58.969Z INFO [connection] Opened connection [connectionId{localValue:1, serverValue:11}] to localhost:27017
2020-03-30T21:00:58.973Z INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 17]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=2593557}
2020-03-30T21:00:58.987Z INFO [connection] Opened connection [connectionId{localValue:2, serverValue:12}] to localhost:27017
2020-03-30T21:00:59.208Z INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers.
2020-03-30T21:00:59.395Z INFO [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
2020-03-30T21:00:59.396Z INFO [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2020-03-30T21:00:59.455Z INFO [JestClientFactory] Using custom ObjectMapper instance
2020-03-30T21:00:59.455Z INFO [JestClientFactory] Node Discovery disabled…
2020-03-30T21:00:59.456Z INFO [JestClientFactory] Idle connection reaping disabled…
2020-03-30T21:01:00.004Z INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy .
2020-03-30T21:01:00.122Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-03-30T21:01:00.139Z INFO [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy .
2020-03-30T21:01:00.195Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-03-30T21:01:00.216Z INFO [connection] Opened connection [connectionId{localValue:3, serverValue:13}] to localhost:27017
2020-03-30T21:01:00.241Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-03-30T21:01:00.289Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-03-30T21:01:00.445Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-03-30T21:01:00.984Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-03-30T21:01:00.987Z INFO [ServerBootstrap] Graylog server 3.2.4+a407287 starting up
2020-03-30T21:01:00.988Z INFO [ServerBootstrap] JRE: Private Build 1.8.0_242 on Linux 4.15.0-91-generic
2020-03-30T21:01:00.988Z INFO [ServerBootstrap] Deployment: deb
2020-03-30T21:01:00.988Z INFO [ServerBootstrap] OS: Ubuntu 18.04.4 LTS (bionic)
2020-03-30T21:01:00.988Z INFO [ServerBootstrap] Arch: amd64
2020-03-30T21:01:01.031Z INFO [PeriodicalsService] Starting 35 periodicals …
2020-03-30T21:01:01.031Z INFO [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2020-03-30T21:01:01.049Z INFO [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2020-03-30T21:01:01.051Z INFO [connection] Opened connection [connectionId{localValue:4, serverValue:14}] to localhost:27017
2020-03-30T21:01:01.052Z INFO [PeriodicalsService] Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Not configured to run on this node.
2020-03-30T21:01:01.052Z INFO [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2020-03-30T21:01:01.058Z INFO [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2020-03-30T21:01:01.059Z INFO [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
2020-03-30T21:01:01.059Z INFO [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2020-03-30T21:01:01.060Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2020-03-30T21:01:01.060Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2020-03-30T21:01:01.060Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2020-03-30T21:01:01.061Z INFO [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2020-03-30T21:01:01.061Z INFO [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2020-03-30T21:01:01.061Z INFO [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2020-03-30T21:01:01.062Z INFO [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2020-03-30T21:01:01.064Z INFO [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2020-03-30T21:01:01.066Z INFO [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2020-03-30T21:01:01.066Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2020-03-30T21:01:01.067Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2020-03-30T21:01:01.079Z INFO [connection] Opened connection [connectionId{localValue:8, serverValue:17}] to localhost:27017
2020-03-30T21:01:01.078Z INFO [connection] Opened connection [connectionId{localValue:5, serverValue:15}] to localhost:27017
2020-03-30T21:01:01.084Z INFO [connection] Opened connection [connectionId{localValue:7, serverValue:18}] to localhost:27017
2020-03-30T21:01:01.085Z INFO [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2020-03-30T21:01:01.087Z INFO [connection] Opened connection [connectionId{localValue:6, serverValue:16}] to localhost:27017
2020-03-30T21:01:01.097Z INFO [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2020-03-30T21:01:01.098Z INFO [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2020-03-30T21:01:01.126Z INFO [Periodicals] Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
2020-03-30T21:01:01.128Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2020-03-30T21:01:01.139Z INFO [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2020-03-30T21:01:01.140Z INFO [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
2020-03-30T21:01:01.141Z INFO [Periodicals] Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
2020-03-30T21:01:01.149Z INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2020-03-30T21:01:01.162Z INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2020-03-30T21:01:01.167Z INFO [Periodicals] Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
2020-03-30T21:01:01.169Z INFO [Periodicals] Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
2020-03-30T21:01:01.178Z INFO [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2020-03-30T21:01:01.179Z INFO [Periodicals] Starting [org.graylog.plugins.license.LicenseManagerPeriodical] periodical in [0s], polling every [300s].
2020-03-30T21:01:01.182Z INFO [Periodicals] Starting [org.graylog.plugins.license.LicenseReportPeriodical] periodical in [300s], polling every [3600s].
2020-03-30T21:01:01.183Z INFO [Periodicals] Starting [org.graylog.plugins.auditlog.mongodb.MongoAuditLogPeriodical] periodical in [0s], polling every [3600s].
2020-03-30T21:01:01.184Z ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2020-03-30T21:01:01.185Z INFO [Periodicals] Starting [org.graylog.plugins.report.scheduler.ReportPeriodical] periodical in [120s], polling every [60s].
2020-03-30T21:01:01.186Z INFO [Periodicals] Starting [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical] periodical in [60s], polling every [180s].
2020-03-30T21:01:01.752Z INFO [JerseyService] Enabling CORS for HTTP endpoint
2020-03-30T21:01:24.133Z INFO [NetworkListener] Started listener bound to [0.0.0.0:9000]
2020-03-30T21:01:24.135Z INFO [HttpServer] [HttpServer] Started.
2020-03-30T21:01:24.135Z INFO [JerseyService] Started REST API at <0.0.0.0:9000>
2020-03-30T21:01:24.148Z INFO [ServerBootstrap] Services started, startup times in ms: {InputSetupService [RUNNING]=3, GracefulShutdownService [RUNNING]=9, OutputSetupService [RUNNING]=10, BufferSynchronizerService [RUNNING]=10, JobSchedulerService [RUNNING]=10, UrlWhitelistService [RUNNING]=15, KafkaJournal [RUNNING]=16, JournalReader [RUNNING]=17, EtagService [RUNNING]=33, ConfigurationEtagService [RUNNING]=52, MongoDBProcessingStatusRecorderService [RUNNING]=64, LookupTableService [RUNNING]=114, StreamCacheService [RUNNING]=160, PeriodicalsService [RUNNING]=180, JerseyService [RUNNING]=23123}
2020-03-30T21:01:24.148Z INFO [ServiceManagerListener] Services are healthy
2020-03-30T21:01:24.149Z INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2020-03-30T21:01:24.156Z INFO [ServerBootstrap] Graylog server up and running.
2020-03-30T21:01:24.156Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
Any help will be appreciated.
