Error injecting constructor, java.lang.IllegalArgumentException: bufferSize must be a power of 2
I a facing the below error, kindly let me know if am missing something.
Below is my server.conf file:
is_master = true
password_secret = fc9b63a79bfd52787b6e93de9befd76acd8971384e3e886763d21800bxxxxxxx
http_publish_uri = http://10.x.x.x:9000/
http_external_uri = http://10.x.x.x:9000/
http_enable_cors = true
elasticsearch_hosts = http://10.x.x.x:9200
elasticsearch_connect_timeout = 10s
elasticsearch_socket_timeout = 60s
elasticsearch_max_total_connections = 200
elasticsearch_max_total_connections_per_route = 20
elasticsearch_max_retries = 2
rotation_strategy = count
elasticsearch_max_size_per_index = 1073741824
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 3
outputbuffer_processors = 2
ring_size = 65536
inputbuffer_ring_size = 6553
inputbuffer_processors = 1
message_journal_max_size = 10gb
Please be more verbose:
  • It’s a new graylog install?
  • Which graylog version do you use
  • Which ElasticSearch and Java version do you use
  • Which linux distribution do you use
  • Type of install OVA, distribution package, docker?
@docgyan
Why are you posting this twice?
I also explained your issue in the other post.
