Hi All,
We are using graylog version 2.3.0 & Elasticsearch 5.5.2 in our environment and I was trying to index csv data to elasticsearch by configuring filebeat but the entire data was not indexed to elasticsearch properly some data were missed.
Below is the sample data,
Title,Shortdescription,knowledgecategory,Description
DNS Issue Resolution,"Open Start
ype command prompt into Start
Click Command Prompt. It's at the top of the Start window. This will open Command Prompt
Type in ipconfig /flushdns and press Enter
Restart your web browser.",Network,
Below is my generated filebeat configuration,
filebeat:
prospectors:
- document_type: log
encoding: plain
exclude_lines:
- ^Title
fields:
data: knowledgedata
gl2_source_collector: f4749ffd-1f9b-4ef1-b065-a8fc32388fa1
ignore_older: 0
input_type: log
paths:
- /var/log/knowledgedata/*.csv
scan_frequency: 10s
tail_files: false
output:
logstash:
hosts:
- graylogdemo.cloudapp.azure.com:5044
loadbalance: false
path:
data: /var/cache/graylog/collector-sidecar/filebeat/data
logs: /var/log/graylog/collector-sidecar
tags:
- linux
- apache
- knowledgedata
Since I am indexing csv files to elasticsearch so I used the csv output plugin in graylog and configured pipeline rule for my knowledge data below is my pipeline rule for csv,
rule "knowledgedata"
has_field("message")
let csv_fields = "Title,Shortdescription,knowledgecategory,description";
let csv_parsed = csv(csv_fields: csv_fields, csv_text: to_string($message.message), csv_separator: ",");
set_fields(csv_parsed);
After the file done harvested through filebeat I can see in Elasticsearch that knowledge data index has below data only,
“Title”: “DNS Issue Resolution”
"Shortdescription": "\"Open Start"
I couldn’t find any other data indexed to elasticsearch.
Please kindly share any thoughts and let me know what changes I need to make in order to index data to Elasticsearch properly
Thanks,
Ganeshbabu R
