Dear all, today I restarted my Graylog Appliance (4.x), now elastichsearc give me this error:
org.elasticsearch.transport.BindTransportException: Failed to bind to [9300-9400]
This is strange , nothings has been modified and before the service restart al the services were up and running. Please, can you help me ? The appliance is internal, with a dedicated internal ip.
[2021-05-26T16:45:58,495][ERROR][o.e.b.ElasticsearchUncaughtExceptionHandler] [adv-syslog-01] uncaught exception in thread [main]
org.elasticsearch.bootstrap.StartupException: BindTransportException[Failed to bind to [::1]:[9300-9400]]; nested: BindException[Cannot assign requested address];
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:174) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:161) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:86) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:127) ~[elasticsearch-cli-7.10.2.jar:7.10.2]
at org.elasticsearch.cli.Command.main(Command.java:90) ~[elasticsearch-cli-7.10.2.jar:7.10.2]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:126) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:92) ~[elasticsearch-7.10.2.jar:7.10.2]
Caused by: org.elasticsearch.transport.BindTransportException: Failed to bind to [::1]:[9300-9400]
at org.elasticsearch.transport.TcpTransport.bindToPort(TcpTransport.java:416) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.transport.TcpTransport.bindServer(TcpTransport.java:380) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.transport.netty4.Netty4Transport.doStart(Netty4Transport.java:131) ~[?:?]
at org.elasticsearch.common.component.AbstractLifecycleComponent.start(AbstractLifecycleComponent.java:59) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.transport.TransportService.doStart(TransportService.java:235) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.node.Node.start(Node.java:812) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.bootstrap.Bootstrap.start(Bootstrap.java:317) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:402) ~[elasticsearch-7.10.2.jar:7.10.2]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:170) ~[elasticsearch-7.10.2.jar:7.10.2]
β¦ 6 more
Caused by: java.net.BindException: Cannot assign requested address
at sun.nio.ch.Net.bind0(Native Method) ~[?:?]
at sun.nio.ch.Net.bind(Net.java:550) ~[?:?]
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:249) ~[?:?]
at io.netty.channel.socket.nio.NioServerSocketChannel.doBind(NioServerSocketChannel.java:134) ~[?:?]
at io.netty.channel.AbstractChannel$AbstractUnsafe.bind(AbstractChannel.java:550) ~[?:?]
at io.netty.channel.DefaultChannelPipeline$HeadContext.bind(DefaultChannelPipeline.java:1334) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeBind(AbstractChannelHandlerContext.java:506) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.bind(AbstractChannelHandlerContext.java:491) ~[?:?]
at io.netty.channel.DefaultChannelPipeline.bind(DefaultChannelPipeline.java:973) ~[?:?]
at io.netty.channel.AbstractChannel.bind(AbstractChannel.java:248) ~[?:?]
at io.netty.bootstrap.AbstractBootstrap$2.run(AbstractBootstrap.java:356) ~[?:?]
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:164) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:472) ~[?:?]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:500) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:989) ~[?:?]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) ~[?:?]
at java.lang.Thread.run(Thread.java:832) [?:?]
Maybe I can help. It looks like from what youβre showing us that it might be configuration error. Some more details would help greatly in troubleshooting your problem like elasticsearch/Graylog configuration files.
I did a quick google search and found these. Maybe there is something in these post that will help you.
