When I start the geolocalisation processor plugin in v4.1 and have the Maxmind database configured, fields get created automatically. Yet the Documentation says that one has to go through the trouble of creating LUTs and e.g. pipeline rules in order to get geolocalisation.
It seems to me that these two ways of configuration can be used independently of one other. Perhaps it could be mentioned in the Docs that one does not need LUTs et al when using the plugin?
For the examples below I have from the outset disabled my Geolocalisation LUT by connecting it to an adapter and cache that have nothing to do with geolocalisation so that LUT would error out. My maxmind database is configured.
The Geo-location processor plugin on the Configurations screen is also disabled.
I get this:
When I enable the Geo-location processor plugin I immediately start to get this:
So the above is being inserted without any LUT or pipeline doing geolocation stuff.
When I do connect the LUT and pipeline I get additional geolocation fields according to my rules, such as:
because my rule is like this:
Actually, the title I gave is misleading, I am not getting duplicate fields, I am getting double fields when I follow the docs. When I enable the plugin I am also prompted to Read more:
I would think that my example above shows that no additional configuration is needed. The LUT seems to me to be superfluous. Does the LUT way of configuring yield other results than using the Geolocation processor?
Thank you for the added info. I tried to duplicate you issue in my lab, but unfortunately I do not have the same results as you do.
Did you just install it or did you make configuration on your own?
Here is mine
rule "GeoIP lookup: src_ip"
has_field("src_ip")
let geo = lookup("geoip", to_string($message.src_ip));
set_field("src_ip_geo_location", geo["coordinates"]);
set_field("src_ip_geo_country", geo["country"].iso_code);
set_field("src_ip_geo_city", geo["city"].names.en);
I’m not finding any duplicates fields.
I think it was easy to setup like in 5 minutes from the documention. Then I waited for messages to come through. That was it “Copy & Paste”.
