If you want to give something back, I’m very interested In your PowerShell command and the setup you did in your environment. I was wondering if you could demonstrate all this here. Not only for my self but others. Sharing is caring
For sure my friend, It will be a pleasure to be helpful to others.
# Credentials
$SQLServer = "1.1.1.1\server"
$db = "dummy_data"
$user = "dummyuser"
$pwd ="dummypass"
#Select to get the sql data
$selectdata = "SELECT TOP 5
[date_time]
,[pc_name]
,[user_name]
,[file_name]
,[operation]
,[action]
,[source_type]
,[destination_type]
,[policy_name]
,[file_extension]
,[file_type]
,[file_size]
,[source_path]
,[destination_path]
,[application_name]
,[data_categories]
,[to_safe_zone]
,[is_tagged]
,[sensitive_content]
,[suspicous]
,[id_user]
,[id_pc]
,[id_application]
,[category_extension]
,[id_policy]
,[policy_bound]
,[module]
,[policy_restriction]
FROM [dummy_data].[pbi].[data_security_view] ORDER BY date_time DESC"
$dump = Invoke-Sqlcmd -ServerInstance $SQLServer -Username $user -Password $pwd -Database $db -Query $selectdata
#loop
for ($count=0; $count -lt $dump.Count; $count++)
#Format the events per line
echo "$("pc_name="+$dump[$count].pc_name) $("user_name="+$dump[$count].user_name) $("file_name="+$dump[$count].file_name) $("operation="+$dump[$count].operation)" >> "C:\Program Files\Management Console\Logs\noencoding_logs.log"
#Convert the output file to ascii and output to a file
Get-Content "C:\Program Files\Management Console\Logs\noencoding_logs.log" | Out-File -Encoding ascii "C:\Program Files\Management Console\Logs\sql_logs.log"
Isn’t pretty As I already have said, but it works, and this will give me more time to implement something more elegant in the future.
Any doubts just asking.
And does this also do the text conversion format?
This line, to be more precise.
Nice and thank you. I was hoping you write up a post under here so you get credit for it.
If not I can write something up for you. This way in about 20 years this would be easy to access
That’s cool, my English it’s not that good but I can try, can I write something and send it to you to check if it’s ok? I just want to know how it’s the format, like a mini-tutorial or something?
Oh course also feel free to DM me if you like. Since this is Friday, I have about 6 more hours here at work then Im playing Video games next two days Actually I have close friends from Switzerland and UK
