Sure @gsmith
Please find the below response,
Graylog version is 3.3.2
Elasticsearch version is 6.8.1
Mongodb version is v3.6.23
We are using open source version of Graylog.
K8s cluster size is 8 cpu core, 32 GB RAM,
Below is the resources we have allocated for Graylog server,
Limits:
cpu: 1
memory: 2Gi
Requests:
cpu: 500m
memory: 1536Mi
Volume for graylog storage I have allocated 10Gi
I am running graylog, elasticsearch, mongo in azure kubernetes cluster (AKS)
I am using linux based OS and I am running Graylog using helm charts.
(charts/charts/graylog at main · KongZ/charts · GitHub)
we have build docker image for graylog collector sidecar and the collector (azurebeat) is part of the image. the image is deployed as pod in the k8s cluster and its talking to graylog. The above configuration I have mapped to the collector to start getting the data from azure envrionments.
Below is the graylog logs which I got on that day when issue occured,
2021-04-03 13:48:00,155 WARN [GelfCodec] - GELF message <3425ef20-9483-11eb-b3f5-4a214cf9ce5b> (received from <10.244.3.253:36734>) is missing mandatory "host" field. - {}
2021-04-03 14:02:12,626 ERROR [AnyExceptionClassMapper] - Unhandled exception in REST resource - {}
com.mongodb.MongoCommandException: Command failed with error 66 (ImmutableField): 'After applying the update, the (immutable) field '_id' was found to have been altered to _id: ObjectId('606875642ee20b6ec9e219cb')' on server igedge-mongodb-edge-headless:27017. The full response is {"operationTime": {"$timestamp": {"t": 1617458532, "i": 28}}, "ok": 0.0, "errmsg": "After applying the update, the (immutable) field '_id' was found to have been altered to _id: ObjectId('606875642ee20b6ec9e219cb')", "code": 66, "codeName": "ImmutableField", "$clusterTime": {"clusterTime": {"$timestamp": {"t": 1617458532, "i": 28}}, "signature": {"hash": {"$binary": "AAAAAAAAAAAAAAAAAAAAAAAAAAA=", "$type": "00"}, "keyId": {"$numberLong": "0"}}}}
at com.mongodb.internal.connection.ProtocolHelper.getCommandFailureException(ProtocolHelper.java:175) ~[graylog.jar:?]
at com.mongodb.internal.connection.InternalStreamConnection.receiveCommandMessageResponse(InternalStreamConnection.java:303) ~[graylog.jar:?]
at com.mongodb.internal.connection.InternalStreamConnection.sendAndReceive(InternalStreamConnection.java:259) ~[graylog.jar:?]
at com.mongodb.internal.connection.UsageTrackingInternalConnection.sendAndReceive(UsageTrackingInternalConnection.java:99) ~[graylog.jar:?]
at com.mongodb.internal.connection.DefaultConnectionPool$PooledConnection.sendAndReceive(DefaultConnectionPool.java:450) ~[graylog.jar:?]
at com.mongodb.internal.connection.CommandProtocolImpl.execute(CommandProtocolImpl.java:72) ~[graylog.jar:?]
at com.mongodb.internal.connection.DefaultServer$DefaultServerProtocolExecutor.execute(DefaultServer.java:226) ~[graylog.jar:?]
at com.mongodb.internal.connection.DefaultServerConnection.executeProtocol(DefaultServerConnection.java:269) ~[graylog.jar:?]
at com.mongodb.internal.connection.DefaultServerConnection.command(DefaultServerConnection.java:131) ~[graylog.jar:?]
at com.mongodb.internal.connection.DefaultServerConnection.command(DefaultServerConnection.java:123) ~[graylog.jar:?]
at com.mongodb.operation.CommandOperationHelper$13.call(CommandOperationHelper.java:710) ~[graylog.jar:?]
at com.mongodb.operation.OperationHelper.withReleasableConnection(OperationHelper.java:501) ~[graylog.jar:?]
at com.mongodb.operation.CommandOperationHelper.executeRetryableCommand(CommandOperationHelper.java:703) ~[graylog.jar:?]
at com.mongodb.operation.CommandOperationHelper.executeRetryableCommand(CommandOperationHelper.java:695) ~[graylog.jar:?]
at com.mongodb.operation.BaseFindAndModifyOperation.execute(BaseFindAndModifyOperation.java:70) ~[graylog.jar:?]
at com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.execute(MongoClientDelegate.java:213) ~[graylog.jar:?]
at com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.execute(MongoClientDelegate.java:182) ~[graylog.jar:?]
at com.mongodb.DBCollection.findAndModify(DBCollection.java:2036) ~[graylog.jar:?]
at com.mongodb.DBCollection.findAndModify(DBCollection.java:1891) ~[graylog.jar:?]
at com.mongodb.DBCollection.findAndModify(DBCollection.java:1858) ~[graylog.jar:?]
at com.mongodb.DBCollection.findAndModify(DBCollection.java:1801) ~[graylog.jar:?]
at org.mongojack.JacksonDBCollection.findAndModify(JacksonDBCollection.java:881) ~[graylog.jar:?]
at org.graylog.plugins.sidecar.services.ActionService.saveAction(ActionService.java:73) ~[graylog.jar:?]
at org.graylog.plugins.sidecar.rest.resources.AdministrationResource.setAction(AdministrationResource.java:166)~[graylog.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_252]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_252]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_252]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_252]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog
.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
2021-04-03 14:18:22,068 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
2021-04-03 15:18:22,203 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
2021-04-03 15:47:00,097 WARN [GelfCodec] - GELF message <d3e3ff10-9493-11eb-b3f5-4a214cf9ce5b> (received from <10.244.3.253:33092>) is missing mandatory "host" field. - {}
2021-04-03 16:04:00,111 WARN [GelfCodec] - GELF message <33dd2bb0-9496-11eb-b3f5-4a214cf9ce5b> (received from <10.244.3.253:44646>) is missing mandatory "host" field. - {}
2021-04-03 16:18:22,143 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
2021-04-03 16:45:00,103 WARN [GelfCodec] - GELF message <ee20a290-949b-11eb-b3f5-4a214cf9ce5b> (received from <10.244.3.253:44382>) is missing mandatory "host" field. - {}
2021-04-03 17:18:22,196 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
2021-04-03 18:18:22,766 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
2021-04-03 19:18:23,472 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
2021-04-03 20:18:22,501 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
2021-04-03 21:18:22,342 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
2021-04-03 22:12:47,208 WARN [GelfCodec] - GELF message <b89d8380-94c9-11eb-b3f5-4a214cf9ce5b> (received from <10.244.4.41:50704>) has invalid "timestamp": 2021-04-03 22:00:00+00:00 (type: STRING) - {}
2021-04-03 22:18:21,872 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
2021-04-03 23:18:22,538 INFO [IndexRangesCleanupPeriodical] - Removing index range information for unavailable indices: [test_discovery_nodes_0] - {}
but for elastic and mongo log I didnt get any error messages and I got these type of messages on that day,
mongo logs,
2021-04-06T05:13:31.042+0000 I NETWORK [listener] connection accepted from 10.244.4.33:58808 #578545 (63 connections now open)
2021-04-06T05:13:31.042+0000 I NETWORK [conn578545] received client metadata from 10.244.4.33:58808 conn578545: { driver: { name: "PyMongo", version: "3.11.3" }, os: { type: "Linux", name: "Linux", architecture: "x86_64", version: "4.15.0-1108-azure" }, platform: "CPython 3.6.9.final.0" }
2021-04-06T05:13:31.051+0000 I STORAGE [conn578545] createCollection: edge_console.mongo_test with generated UUID: ec9bf198-4682-47b9-a42b-b8cd09245391
2021-04-06T05:13:31.110+0000 I COMMAND [conn578545] CMD: drop edge_console.mongo_test
2021-04-06T05:13:31.110+0000 I STORAGE [conn578545] dropCollection: edge_console.mongo_test (ec9bf198-4682-47b9-a42b-b8cd09245391) - renaming to drop-pending collection: edge_console.system.drop.1617686011i6t3.mongo_test with drop optime { ts: Timestamp(1617686011, 6), t: 3 }
2021-04-06T05:13:31.175+0000 I REPL [replication-3350] Completing collection drop for edge_console.system.drop.1617686011i6t3.mongo_test with drop optime { ts: Timestamp(1617686011, 6), t: 3 } (notification optime: { ts: Timestamp(1617686011, 6), t: 3 })
2021-04-06T05:13:31.175+0000 I STORAGE [replication-3350] Finishing collection drop for edge_console.system.drop.1617686011i6t3.mongo_test (ec9bf198-4682-47b9-a42b-b8cd09245391).
2021-04-06T05:13:32.486+0000 I NETWORK [listener] connection accepted from 127.0.0.1:36478 #578546 (64 connections nowopen)
2021-04-06T05:13:32.488+0000 I NETWORK [conn578546] received client metadata from 127.0.0.1:36478 conn578546: { application: { name: "MongoDB Shell" }, driver: { name: "MongoDB Internal Client", version: "3.6.23" }, os: { type: "Linux", name: "PRETTY_NAME="Debian GNU/Linux 9 (stretch)"", architecture: "x86_64", version: "Kernel 4.15.0-1106-azure" } }
2021-04-06T05:13:32.492+0000 I NETWORK [conn578546] end connection 127.0.0.1:36478 (63 connections now open)
2021-04-06T05:13:33.640+0000 I NETWORK [listener] connection accepted from 127.0.0.1:36500 #578547 (64 connections now open)
2021-04-06T05:13:33.641+0000 I NETWORK [conn578547] received client metadata from 127.0.0.1:36500 conn578547: { application: { name: "MongoDB Shell" }, driver: { name: "MongoDB Internal Client", version: "3.6.23" }, os: { type: "Linux", name: "PRETTY_NAME="Debian GNU/Linux 9 (stretch)"", architecture: "x86_64", version: "Kernel 4.15.0-1106-azure" } }
2021-04-06T05:13:33.647+0000 I NETWORK [conn578547] end connection 127.0.0.1:36500 (63 connections now open)
Elastic logs,
[2021-04-06T05:19:14,303][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [auto_generate_phrase_queries] used, replaced by [This setting is ignored, use [type=phrase] instead to make phrase queries out of all text that is within query operators, or use explicitly quoted strings if you need finer-grained control]
[2021-04-06T05:19:14,303][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [split_on_whitespace] used, replaced by [This setting is ignored, the parser always splits on operator]
[2021-04-06T05:19:14,303][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [disable_coord] used, replaced by [disable_coord has been removed]
[2021-04-06T05:19:14,303][WARN ][o.e.d.s.a.I.Parser ] [elasticsearch-master-1] Deprecated aggregation order key [_term] used, replaced by [_key]
[2021-04-06T05:19:28,212][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [use_dis_max] used, replaced by [Set [tie_breaker] to 1 instead]
[2021-04-06T05:19:28,212][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [auto_generate_phrase_queries] used, replaced by [This setting is ignored, use [type=phrase] instead to make phrase queries out of all text that is within query operators, or use explicitly quoted strings if you need finer-grained control]
[2021-04-06T05:19:28,212][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [split_on_whitespace] used, replaced by [This setting is ignored, the parser always splits on operator]
[2021-04-06T05:19:28,212][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [disable_coord] used, replaced by [disable_coord has been removed]
[2021-04-06T05:19:28,212][WARN ][o.e.d.s.a.I.Parser ] [elasticsearch-master-1] Deprecated aggregation order key [_term] used, replaced by [_key]
[2021-04-06T05:19:28,270][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [use_dis_max] used, replaced by [Set [tie_breaker] to 1 instead]
[2021-04-06T05:19:28,270][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [auto_generate_phrase_queries] used, replaced by [This setting is ignored, use [type=phrase] instead to make phrase queries out of all text that is within query operators, or use explicitly quoted strings if you need finer-grained control]
[2021-04-06T05:19:28,270][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [split_on_whitespace] used, replaced by [This setting is ignored, the parser always splits on operator]
[2021-04-06T05:19:28,270][WARN ][o.e.d.c.ParseField ] [elasticsearch-master-1] Deprecated field [disable_coord] used, replaced by [disable_coord has been removed]
[2021-04-06T05:19:28,270][WARN ][o.e.d.s.a.I.Parser ] [elasticsearch-master-1] Deprecated aggregation order key [_term] used, replaced by [_key]
