Change 10% disk block index
Dear , I can prevent and change the index.blocks.read_only_allow_delete value? currently when I reach 10% indexes are blocked. So , How I can chenge the value to 5% ?
Not sure what version you have… Always better to fix by adding disk space or removing unneeded data… Here is a link to Elasticsearch (master) that talks about changing these settings:
You should also review your retention settings. Make sure you set the index to delete at some point. If you don’t, you’re disk will always eventually fill up.
