Cannot make ListField not optional
I cannot make a ListField not optional in a alert plugin. In fact the check function in configuration Request doesn’t contain the ListField switch case. There is a way to make ListField not optional or the case in the switch can be add?
Please provide some example code illustrating what you want to achieve.
In this fonction there is no case for the type ListField so I get the IllegalStateException("Unknown field type " + type + “. This is a bug.”);
Please create a bug report for this at https://github.com/Graylog2/graylog2-server/issues.
