i am using graylog 2.2.3, sidecar collector 0.1.1 and filebeat 5.4.0. If i create a beat input with tls communication and sidecar read the configuration from the graylog server and create a filebeat config file, in the config file is a tls section with the certificate name and so on. But filebeat don’t use a secure communication and sends message with http and not https. I think, in the configuration file for file beat must be a ssl section, not a tls section. If i create a snippet with ssl section as described in the file beat documentation, the communication works with https.
It is a bug, that a tls section is created?
Winschi
