Archive Output Path and file Format
Hi All,
there’s a way to write the output archives with custom name, intead of custom folders ?
I.E. I need the following format for main index archive:
/mnt/myarchive/2018-10-25-main_archive or something like, I can get this work with folders
like this /mnt/myarchive/2018/10/25/main_archive but our archive system can’t read that.
Any suggestion ?
the given customization of the path is the only you can change in the archiving.
You would need to write your own archiving plugin to get the result you like to have.
Hi Jan,
thanks for the hint, I will do that.
Regards
